HOW TO
This article shows how to add a new item to a coverage feature class in ArcMap.
Code in ThisDocument module will only run in the current map document. To store the code in all your map documents, open the Normal.mxt ThisDocument code module.
Code:
Public Sub additem()
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Dim pFLayer As IFeatureLayer
' Get the first layer in ArcMap
Dim pCovFClass As ICoverageFeatureClass
Set pFLayer = pMxDoc.FocusMap.Layer(0)
Set pCovFClass = pFLayer.FeatureClass
Dim pArcItem As IArcInfoItem
Dim pArcItemEdit As IArcInfoItemEdit
Dim pFClass As IFeatureClass
Set pFClass = pFLayer.FeatureClass
Dim pArcTable As IArcInfoTable
Set pArcTable = pCovFClass
' Check to see if an item called newitem exists
' and create the item if it doesn't
If pFClass.FindField("newitem") = -1 Then
Set pArcItem = New ArcInfoItem
Set pArcItemEdit = pArcItem
With pArcItemEdit
.Name = "newitem"
.Type = esriFieldTypeString
.Width = 1
.OutputWidth = 1
End With
pArcTable.additem pArcItem, "test"
End If
Article ID:000004942
Get help from ArcGIS experts
Download the Esri Support App
