HOW TO
Add an Annotation FeatureClass from a Personal Geodatabase to ArcMap with ArcObjects
Summary
This article pertains to ArcGIS versions 8.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Instructions provided describe how to add an Annotation FeatureClass to ArcMap. In this example the annotation resides in a Personal GeoDatabase.
Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
Procedure
  1. Start ArcMap.
  2. Create a new UIButtonControl: How To: Create a new UIButtonControl
 For more information on creating a UIControl, see the ArcGIS Desktop Help topic 'Creating custom commands with VBA and UI Controls'
  1. Right-click the UIButtonControl and select View Source.
  2. Copy below code into the UIButtonControl's click event.
Dim strPathName As String
strPathName = "D:\temp\yellowstone.mdb" ' Replace with the name of your Personal Geodatabase
  1. Modify the value of strPathName to reflect the location of your personal geodatabase.
  2. Copy the code below into the UIButtonControl's click event, immediately after the code you entered in Step 4.
Dim strData As String
strData = "AnnoRoad" ' Replace with the name of your annotation FeatureClass
  1. Modify the value of strData to point to the annotation Feature Class in your Personal Geodatabase.
  2. Copy the code below into the UIButtonControl's click event, immediately after the code you entered in Step 6.
' Set up the WorkspaceFactory
Dim pWorkspaceName As IWorkspaceName
Set pWorkspaceName = New WorkspaceName
pWorkspaceName.WorkspaceFactoryProgID = "esricore.AccessWorkspaceFactory"
pWorkspaceName.PathName = strPathName
Dim pDatasetName As IDatasetName
Set pDatasetName = New FeatureClassName
pDatasetName.Name = strData
Set pDatasetName.WorkspaceName = pWorkspaceName
' Use a lightweight Name object to open the table.
Dim pName As IName
Set pName = pDatasetName  ' QI
Dim pTable As ITable
Set pTable = pName.Open
Dim pFeatClass As IDataset
Set pFeatClass = ptable
Dim pFeatLay As IFeatureLayer
'IFDOGraphicsLayerFactory::OpenGraphicsLayer IS THE KEY to accessing the data!
Dim pFDOGraphicsLayerFactory As IFDOGraphicsLayerFactory
Set pFDOGraphicsLayerFactory = New FDOGraphicsLayerFactory
' Modify this line of code
Set pFeatLay = pFDOGraphicsLayerFactory.OpenGraphicsLayer(pfeatclass.Workspace, Nothing, "AnnoRoad")
'Assign the name in the Table of Contents
pFeatLay.Name = pFeatClass.Name
' Add the annotation to ArcMap
Dim pMap As IMap
Dim pMxDoc As IMxDocument
Set pMxDoc = ThisDocument
Set pMap = pMxDoc.ActiveView
pMap.AddLayer pFeatLay
Dim pAV As IActiveView
Set pAV = pMap
pAV.Refresh
  1. Modify the third argument passed to the OpenGraphicsLayer method to point to the input annotation Feature Class.
  2. Test the code.
Article ID:000004181
Software:
  • ArcMap 8 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
