HOW TO
Note: This article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
With versions earlier than ArcGIS 8.2, you can not define a subset of records for a table in ArcMap. You can specify a Definition query for a Layer so that the layer is comprised of only the records that match the query however, this functionality is not available for tables in ArcMap.
If the tabular data is stored in an RDBMS, which supports table views and can receive SQL statements, you can add a subset of records to ArcMap. The VBA code in this article connects to the database using OLE DB, then sends a SQL command to the database that creates a view comprised of a subset of records. The view is then added to ArcMap as a table.
Note: There are other methods to accomplish this task using later versions of ArcGIS
Note: Support for Visual Basic for Applications (VBA) for ArcMap and ArcCatalog ended with the ArcGIS 10.2.2 release, and Esri has not included VBA compatibility setups since version 10.5. See: ArcGIS Desktop and VBA Moving Forward
'++ adds an OLE DB table
On Error GoTo ErrorHandler:
'++ New property set for workspacefactory
Dim pPropset As IPropertySet
Set pPropset = New PropertySet
'++ Provider = MS OLE DB provider for Oracle.
'++CHANGE #1
pPropset.SetProperty "CONNECTSTRING", "DSN=OraODBC;UID=UName;PWD=UName;SERVER=Oracle.Test"
Dim pWorkspaceFact As IWorkspaceFactory
Set pWorkspaceFact = New OLEDBWorkspaceFactory
'++ Create the new workspace/feature workspace objects
Dim pWorkspace As IWorkspace
Set pWorkspace = pWorkspaceFact.Open(pPropset, 0)
Dim pFeatWorkspace As IFeatureWorkspace
Set pFeatWorkspace = pWorkspace
'++ If a sub-set of the table is required and views are supported by the data source
'++ create a view of the table selection you wish to use.
Dim SQLstr As String
'++CHANGE #2
SQLstr = "create view NEWVIEW as select * from STREETS where STATUS = 'CURRENT' "
'++ Create the view and fetch the datasetnames from the workspace
pWorkspace.ExecuteSQL SQLstr
Dim pEnumDataset As IEnumDatasetName
Dim pDataset As IDatasetName
Set pEnumDataset = pWorkspace.DatasetNames(esriDTAny)
Set pDataset = pEnumDataset.Next
Do Until pDataset Is Nothing
'++CHANGE #3
If pDataset.Name = "UName.NEWVIEW" Then
Exit Do
End If
Loop
'++ Create the new table object from the dataset name
Dim pTable As ITable
Set pTable = pFeatWorkspace.OpenTable(pDataset.Name)
Dim pDoc As IMxDocument
Set pDoc = ThisDocument
Dim pMap As IMap
Set pMap = pDoc.FocusMap
Dim pTabCol As ITableCollection
Set pTabCol = pMap
pTabCol.AddTable pTable
Dim pTableName As IName
Dim pDS As IDataset
Set pDS = pTable
Set pTableName = pDS.FullName
Exit Sub
ErrorHandler:
MsgBox Err.Number & Err.Description
SQLstr = "create or replace view NEWVIEW as select * from STREETS where STATUS = 'CURRENT'MS Access:
Note: The view must not already exist in an Access database.
Article ID: 000004781
Get help from ArcGIS experts
Start chatting now
