If you receive an HTTP 404 error while trying to activate ArcGIS products through the Software Authorization Wizard (SAW), there are two possible reasons:
- The Esri Software Activation Service (SAS) may be unavailable due to maintenance or other temporary issues.
- You are trying to activate an older ArcGIS Product where online activation is no longer supported. The list of affected products is as follows:
- ArcGIS Desktop 10.0 and prior (Windows)
- ArcGIS Engine 10.0 and prior (Windows)
- ArcGIS Engine (all versions – Linux)
- ArcGIS Server 10.0 and prior (Linux)
- ArcGIS License Manager 2020.0 and prior (Linux)
- ArcGIS CityEngine 2015.1 and prior (Linux)
Solution or Workaround
If your product is not in the above list, please try authorizing again after a few hours. If the problem continues to persist, please contact Esri Technical Support or the support team at your local distributor.
If your product is in the above list:
- Upgrade your software, if possible, to a later version and retry authorizing.
- If upgrade of your software is not possible, please use the offline authorization method available in the Software Authorization Wizard:
- Launch the Software Authorization Wizard (this may need to be launched from the ArcGIS Administrator or License Server Administrator).
- In the second dialog, after choosing what you will authorize, choose Authorize at Esri’s website or by email to receive your authorization file.
- Step through the next dialogs adding, your authorization information as applicable.
- In the final dialog, choose to Save your authorization information, browse to a save location, and select Finish. A file named “authorize.txt” will be generated.
- In your preferred email client, attach the “authorize.txt” file created in step 4 and send it to: authorize@esri.com. Write authorization file in the subject line.
- After a short period of time, a file will be returned to your email address containing either a *.respc, *.resps, or an *.ecp file. Copy this to the host machine being authorized and double-click the file. The relevant Software Authorization Wizard will be automatically opened.
- Step through all dialogs of the Software Authorization Wizard by pressing Next. At completion of authorization, a summary will be displayed confirming a successful authorization.
If you are still unable to authorize after attempting the above steps, please contact Esri Technical Support or the support team at your local distributor.
