PROBLEM
Acetate layer does not show up on the map
An acetate layer added to a map does not show up as expected.
Cause
One of the possible reasons is that the acetate layer ID is a duplicate of the ID of an existing layer. In such a case, the existing layer will be drawn on the map instead of the acetate layer.
Solution or Workaround
When you add an acetate layer, you should always assign a unique ID to it.
The layer ID is of type string and can contain aplha-numeric characters, it would be a good idea to provide meaningful value for id.
For example: id="acetatelayer1" instead of id="33"
    Article ID: 000006087
    Software:
    • Legacy Products
    Download the Esri Support App
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Go to download options
