HOW TO
Access and export ArcGIS Monitor Server logs
First Published: September 28, 2023
Last Published: September 28, 2023
Summary
There may be times when users need to view logs outside of the ArcGIS Monitor Server web application. Follow the steps below to view and export the logs to SQL, CSV, or JSON format.
Procedure
  1. Download and install DB Browser for SQLite.
  2. Launch DB Browser for SQLite and open the file agm-logs.sqlite, located at: C:\Users\<serviceAccount>\AppData\Local\ESRI\ArcGISMonitor\config-store-server\logs, where <serviceAccount> is the Windows service account running ArcGIS Monitor Server.
  3. Click File > Export. Choose one of the following options:
    • Database to SQL File
    • Table(s) as CSV File
    • Table(s) as JSON
Article ID: 000031073
Software:
  • ArcGIS Monitor Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
