PROBLEM
Using the Geoprocessing Server to process a job created with the Generate to Coverage Wizard never finishes processing.
A remote geoprocessing job, from the Generate to Coverage Wizard, may never complete if the input generate file is defined using a Universal Naming Convention (UNC) path.
There is a known problem with using UNC paths in the generate module.
Code:
/* Begin: Generate to Coverage Wizard
/* Aml script created with ArcToolBox for tool: Generate to Coverage Wizard
/* Editing this file may make it unreadable to the ArcToolbox
Precision Single Highest
Precision DOUBLE
Generate d:\wksp\outputcov
Input \\gpsComputer\temp\file.gen
Polygons
quit
/* End: Generate to Coverage Wizard
Code:
Precision DOUBLE
Generate \\mymachine\wksp\outputcov
Input c:\temp\file.gen
Polygons
quit
Article ID:000003096
Get help from ArcGIS experts
Download the Esri Support App
