PROBLEM
A generic error is returned when running the Pivot Table tool
First Published: May 5, 2016
The Pivot Table (Data Management) tool creates an Output Table from an Input Table by reducing redundant records and flattening one-to-many relationships. In some instances, using the tool fails and returns a generic error, “Error 999999: Error executing function.”
Cause
This error is caused by the presence of NULL values in the field used for the pivot field.
Solution or Workaround
Remove the NULL values or replace them with other values, such as zero.
If background processing is turned on, the error message, "Error 001143: Background server threw an exception" may be returned. This is also caused by NULL values in the pivot field, and the NULL values must be removed or replaced.
Article ID: 000012238
Software:
  • ArcMap
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
