ERROR
000871 : Unable to delete the output
First Published: May 5, 2016
Error Message
"000871 : <value>: Unable to delete the output <value>."
Cause
A dataset with the same name as that specified for the output already exists, and it could not be deleted during execution.
Solution or Workaround
  • Verify whether the existing dataset is being held by another application (another ArcMap or ArcCatalog session or the file explorer) and thus is locked. If so, either release the dataset from the application or close it.
  • Check that write permission has been enabled to the output location.
Article ID: 000011476
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
