ERROR
000443: Problems were encountered; <value> contains the full description of the issues
First Published: April 13, 2026
Last Published: April 13, 2026
Error Message
When executing the Calibrate Routes tool in ArcGIS Pro, the following error is encountered:
Error 000443: Problems were encountered; <value> contains the full description of the issues.
Additionally, the output file path displays the following message:
The measure value is outside of the output M domain.
Cause
The issue can be traced to a mismatch between the M Domain values of the route geometry and the measure values being applied during calibration. Specifically:
  • The original route had an Output M Domain that did not accommodate the measure values used in the calibration process.
  • Running Check Geometry on the original route revealed no structural issues.
Solution or Workaround
Adjust the Output M Domain settings in the Calibrate Routes tool:
  • Set the Minimum M value to -1 (instead of the default 0).
    • Optionally, keep the Maximum M value unchanged.
Article ID: 000038498
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
