ERROR
When attempting to import ArcGIS Pro Named User licenses into ArcGIS License Manager, the import process is halted, and the following error message is returned:
Error: Error: a port number must be specified as the last field in the first line of the service.txt file. The recommended range is 27000 to 27009.
The ArcGIS License Manager service.txt file is incorrectly configured and contains a symbol in the port range section.
To resolve the error, open the ArcGIS License Manager service.txt file, and edit the file to ensure there are no symbols in the port range.
C:\Program Files (x86)\ArcGIS\LicenseManager\bin
SERVER this_host ANY 27000 VENDOR ARCGIS PORT=<portvalue>
Note: Any value between 27000 and 27009 can be used for VENDOR ARCGIS PORT.
