HOW TO
The heap size setting controls the maximum payload that can be traversed by the client, it is set at the service level. This is important to be aware of when working with ArcGIS Pro in an enterprise deployment of the utility network and executing a trace operation that traverses a large number of features.
Network errors such as the following can be encountered if the payload of a trace operation is larger than what can be accommodated by the default heap size of 64 MB.
“Error 160213 or Error 003642: A networking error occurred.”
The trace result payload exceeds the default heap size set on the service. The default heap size for each service is 64 MB.
Review the topic Geoprocessing service setting: Advanced properties for information on how to update the heap size setting for a utility network service.
To determine the proper heap size setting for a utility network service needed to estimate the total number of junction and edge elements traversed by a trace, consider the following:
The following baselines can be used to estimate the proper heap size setting for a utility network service.
It is important to understand that the existence of midspan connectivity along a line creates multiple edge elements for a single feature.
