HOW TO
Site Scan Manager for ArcGIS enables sharing custom analysis displays with members external to the project. It is possible to choose the view receivers can see from the many features inside the analysis panel, such as layers, files and measures.
Note: Any other feature turned on in the layers or files tabs is displayed in the receiver's view (including the orthomosaic). To avoid this, turn off all other features not meant for sharing.
Consider the following when using this functionality:
