HOW TO
Instructions provided describe how to plan a flight in Site Scan Flight for ArcGIS without Wi-Fi or cellular network access.
Cases of flight plans in use
Plan flights from the home screen
After flying
After the vehicle lands, select Save as Flight Plan. This works for new flights and re-flying existing flights.
Note: Re-fly can be accessed at the top of the Flight Plans menu tab. Download maps in the Flight Plans menu for use offline. This saves the map at the location and zoom level on the screen, with the flight path. Only the name of a flight plan can be edited without creating a new plan. This ensures data are consistent for future analysis. Flight plans can be duplicated and renamed if the user wants the flight path to remain the same but the flight settings to be different.
