HOW TO
Creating a multiple-page ArcGIS Survey123 form helps to organize a survey into sets of related groups or questions. This creates a more user-friendly experience when answering the survey.
Follow the instructions below to create a multiple-page form using ArcGIS Survey123 Connect or the Survey123 web designer.
Note: With ArcGIS Survey123 Connect 3.6 and later versions, it is not possible to configure a survey form with multiple tabs.
Note: Questions, groups, or repeats that are not specified with field-listappear on all pages.
The images below show the appearance of a multiple-page survey form on various platforms.
To put multiple groups on a single page, create nested groups (secondary groups within a primary group), and select field-list for the begin group type of the primary group. The image below shows two primary groups, each with two secondary groups.
The image below shows the Form Preview tab of the two groups configured on a single page.
ArcGIS Survey123 web designer
The image below shows the new page and the corresponding Edit tab for the new page.
To merge two pages, select the pages, and click either the Merge with the previous page or Merge with the next page icon at the top right corner.
