Häufig gestellte Frage (FAQ)
If you don’t have access to Google Play or the Windows Store, and it is necessary to download the latest version of Collector for ArcGIS to an Android or Windows device, Esri provides setups that can be downloaded and installed on the device.
While downloading Collector for ArcGIS from Google Play or the Windows Store is the recommended method, it is also possible to download Collector from Esri to a workstation and install it on the device.
