Häufig gestellte Frage (FAQ)
Können die Beschriftungen in einem Feature-Layer je nach Feature farblich unterschiedlich formatiert sein?
Last Published: September 13, 2023
Antwort
To create labels for different features have different colors in a feature class, it is necessary to create label classes. This can be done using the ESRI.ArcGIS.Carto.IAnnotateLayerProperties interface, as shown in the following example:
Pseudo Code Example:
IAnnotateLayerProperties.Class = "Class1" // Create one or more classes to represent each label color
IAnnotateLayerProperties.WhereClause = "Pop2000 > 4000" // Criteria for selecting the features to label with this color
Cast IAnnotateLayerProperties to ILabelEngineLayerProperties to set Symbol properties for the label
ILabelEngineLayerProperties.Symbol gives an ITextSymbol, which has a Color property. Use this to change the color
ILabelEngineLayerProperties.Expression = " \"State Name: \"[STATENAME] " // Actual label content
Artikel-ID:000016570
Technischen Support kontaktieren
Zu den Download-Optionen
Zugehörige Informationen
