HOW TO
When registering a database with ArcGIS Server's data store, and the data is versioned, usually the connection is for the default version. This is the case unless otherwise specified. When publishing data to ArcGIS Server from a different version, a separate database connection in the data store is necessary.
A single database connection is only valid for one version of the data. This is the case in ArcGIS Server's data store as well as ArcCatalog's Database Connections list. While different versions can be specified in an MXD, the connection itself only points to one version at a time.
There are two methods to register a non-default geodatabase version with ArcGIS Server's data store:
Create a database connection in ArcCatalog that points to the desired version, and register it with ArcGIS Server's data store
This is generally the best approach. To do this, follow these steps as needed:
Edit the connection in the Service Editor
This method will work if the database connection points only to the default version but the version is modified within the MXD.
After making the connection, Feature Access can be chosen if necessary, and the publishing process can be re-analyzed and published. If Feature Access was specified prior to analyzing, the database registration window will be different, and this process will not work.
The only place that shows the difference between the various versions in the data store is in ArcGIS Server Manager:
