HOW TO
In some cases, there are ZIP Codes that appear to be missing from the current list of available Esri ZIP Codes. This article provides the workflow to determine if a ZIP Code is available or not included in the list.
Navigate to the following site, USPS.COM: Look Up a ZIP Code.
Note: To search for another ZIP Code, click Look up another ZIP Code, and enter the desired ZIP Code in ZIP Code, and click Find.
