Häufig gestellte Frage (FAQ)
There are different versions for the Data Interoperability extension. ArcMap is a 32-bit application, and ArcGIS Pro is 64-bit, so the version of the extension depends on the application used.
To find the build number for the version of Data Interoperability extension installed with ArcMap, open ArcCatalog or ArcMap and click Customize > Extensions. Select the Data Interoperability extension from the list of installed extensions. The build number is displayed at the bottom of the window.
The build number for the Data Interoperability extension installed with ArcMAp 10.5.1 is 17271, as demonstrated in the screenshot below.
The table below shows the versions of ArcMap and their corresponding Data Interoperability build numbers.
ArcMap version | Data Interoperability Build # |
9.3.1 | 5658 |
10.0 | 6213 |
10.0 SP1 / SP2 | 6233 |
10.1 | 12229 |
10.1 SP1 | 12265 |
10.2 / 10.2.1 | 13540 |
10.2.2 | 14241 |
10.3 | 14411 |
10.3.1 | 15245 |
10.4 | 15573 |
10.4.1 | 16177 |
10.5 | 16661 |
10.5.1 | 17271 |
10.6 | 17650 |
10.6.1 | 18301 |
10.7 | 18567 |
10.7.1 | 19238 |
10.8 | 19630 |
10.8.1 | 20218 |
Note: Prior to version 10.1 of ArcGIS Desktop, the Data Interoperability extension was included with all other extensions in the software download. To better coordinate the distribution of the Data Interoperability extension with Safe Software, at 10.1 and subsequent versions, Data Interoperability is now separately downloaded and installed.
