PROBLEM
After publishing a mosaic dataset to an image service, the imagery does not display at all scales.
There are several possible causes for the imagery to not display. These causes are typically related to folder access and permissions but can also be related to the overviews.
Complete the checks below to determine the exact cause and correct the issue.
Note: By default, the overviews are generated and stored in a folder next to where the mosaic dataset resides. This folder has the same name as the geodatabase, with an .overview extension. However, if the mosaic dataset is created in an ArcSDE geodatabase, the overviews will be created within that geodatabase.
Note: Verify that there are not any leading or trailing spaces in the path as they will break the mosaic dataset.
Note: It is recommended that UNC paths be used when loading data into the mosaic dataset.
Note: There are other methods for viewing the source paths so that they can be analyzed and repaired. Refer to ArcMap: Repairing paths in a mosaic dataset.
Note: Instructions regarding ArcGISSOC (server object container) are only applicable to Enterprise 10.0 and earlier.
