HOW TO
Note: This article pertains to ArcGIS versions 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Instructions provided describe how to copy selected annotation features into a new annotation feature class.
Note: This procedure assumes that a second annotation feature class has already been created in the geodatabase; the annotation features must be copied into this empty annotation feature class. This procedure is a modification of the ESRI Knowledge Base article linked in the Related Information section below.
