ERROR
When labeling features with 'define classes of features and label each class differently', the following error message is returned and no labels appear on the map:
"One or more layers failed to draw: An invalid SQL statement was used. [ ]"
On the Layer Properties dialog box > Labels tab, multiple label classes can be defined for a single layer in the Method drop-down list. Each label class is defined by a SQL query. If this query has invalid syntax, this error message appears and labels are not drawn.
It is possible to get label classes with invalid SQL syntax by using the Get Symbology Classes option. Clicking this button automatically builds label classes to match the symbology classes. The above error message can occur because of the following reasons:
Correct the invalid SQL syntax by editing the query for each label class.
Note: For the scenario stated in the cause, use a period (.) instead of a comma (,) as a decimal delimiter. Incorrect: "AREA" > 66,063000 AND "AREA" <= 70812,056000 Correct: "AREA" > 66.063000 AND "AREA" <= 70812.056000
