HOW TO
Note: This article pertains to ArcGIS versions 8.x and 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
This article explains how to set up filter ranges when using bitgate weights in weight filters.
This example works with a geometric network that models electric phases. The geometric network contains a 3-bit bitgate weight to model the three electric phases (A, B, and C). Each phase is represented by one of the three bits:
Each permissible numerical value must be entered in the weight filter range. For example:
