ERROR
Es kann keine sichere Verbindung mit dem Layer hergestellt werden. Der Layer [layername] kann der Karte nicht hinzugefügt werden.
Fehlermeldung
When attempting to add an ArcGIS Server web service through HTTP to an ArcGIS Online web map through HTTPS, the following error message may be returned:
"Unable to establish a secure connection to the layer. The layer, [layername], cannot be added to the map."
[O-Image]
Ursache
The ArcGIS Online organization allows access through HTTPS only; therefore, content accessed through HTTP cannot be added to the web map.
Please see the following ArcGIS Online help topic: Configure security settings
Lösung oder Problemumgehung
Add the GIS web service through HTTPS.
Artikel-ID: 000013245
Zu Download-Optionen wechseln
