HOW TO
Synchronisieren eines Data Store-Elements mit einem Python-Skript bei Verwendung der tokenbasierten Authentifizierung
Last Published: September 12, 2023
Zusammenfassung
Starting with Portal for ArcGIS 10.7.1, users can register user-manager data stores by adding a data store item to the portal. When a user's create data stores items in their portal organization, it allows users to create web layers in bulk from the items inside the enterprise geodatabase.
Ursache
When items are added or removed from the enterprise geodatabase, users can manually synchronize the enterprise geodatabase with the data store item in the portal. However, some users may want to automate the syncing process using a Python script.
Vorgehensweise
Below is one method to synchronize the data store item with Python:
import urllib, urllib2, json, ssl, arcpy, requests
# Generate Portal token
username = "<enter user name>"
password = "<enter password>"
tokenURL = 'https://<enter portal URL>/portal/sharing/rest/generateToken/'
param_1 = {'f': 'pjson', 'username': username, 'password': password, 'referer': 'https://<enter portal URL without web adaptor>'}
req = urllib2.Request(tokenURL, urllib.urlencode(param_1))
try:
    response = urllib2.urlopen(req)
except:
    gcontext = ssl.SSLContext(ssl.PROTOCOL_TLSv1_2)
    response = urllib2.urlopen(req, context=gcontext)
data = json.load(response)
token = data['token']
print(token)
# Sync the Data Store item in Portal
publishURL = 'https://<enter portal URL>/portal/sharing/rest/portals/self/datastores/allDatasets/publishLayers'
param_2 = {'datastoreId': '<enter datastore ID>',
                   'templateSvcConfig': {"serviceName":'null',"type":"MapServer","capabilities":"Map,Query","extensions":[{"typeName":"FeatureServer","capabilities":"Query","enabled":"true","properties":{"maxRecordCount":"4000"}}]},
                   'f': 'json',
                   'token': token}
req = urllib2.Request(publishURL, urllib.urlencode(param_2))
try:
except:
print('Syncing')
Artikel-ID: 000022854
Zugehörige Informationen
Zu Download-Optionen wechseln
