PROBLEM
In ArcGIS Pro, maps can be exported as a PDF file that are designed to be consistently viewable and printable across different platforms. To search for a specific keyword in a PDF file, the Search or Find box is used in a PDF reader.
After exporting a map to PDF from ArcGIS Pro, texts from labels on the map cannot be searched from the Search or Find box in a PDF reader, as shown in the next image, where Adobe Acrobat returns the error message:
Adobe Acrobat has finished searching the document. No matches were found.
The ‘Output as image’ check-box was checked in the Export Map Properties pane before exporting the map as a PDF.
Ensure that the Output as image check-box is unchecked in the Export Map dialog box before exporting the map as a PDF.
Labels can now be searched using the Find box in the PDF reader as shown in the image below.
Artikel-ID: 000027716
