PROBLEM
Beim Konfigurieren eines Workforce for ArcGIS-Projekts ist die Registerkarte "Benutzer" leer
First Published: July 19, 2017
Beschreibung
In some cases, when configuring the Users tab of an ArcGIS Workforce project, the tab is blank and no information is displayed.
Screenshot of the blank Users tab in Workforce for ArcGIS.
Ursache
The user is deleted from the ArcGIS Online organization before the user is removed from the Workforce project. This is a known limitation.
Lösung oder Problemumgehung
To regain access to the Users tab in Workforce, re-add the deleted ArcGIS Online user to the ArcGIS Online organization before deleting the user from Workforce.
  1. Add the deleted ArcGIS Online user to the ArcGIS Online organization. For more information on adding members to an ArcGIS Online organization, refer to ArcGIS Online: Invite and add members.
  2. Once the Users tab can be accessed, remove the user from the Workforce project. For more information on removing users from a Workforce project, refer to ArcGIS Workforce: Tip - Remove users from a project.
  3. Once the user is removed from the project in Workforce, delete the user from the ArcGIS Online organization. For more information on deleting a member from an ArcGIS Online organization, refer to the following ArcGIS Online: Delete member.
Artikel-ID: 000016412
Zugehörige Informationen
Zu Download-Optionen wechseln
