PROBLEM
In ArcGIS Pro, the Near tool calculates the distance between features of different layers or feature classes on a map. Sometimes, the Near tool generates output values beyond the search radius of the tool.
The tool's search radius unit does not match the feature layer’s coordinate system linear unit. Refer to ArcGIS Pro: Usage for more information regarding the linear units used in the NEAR_DIST field of the Near tool.
Use the Calculate Field tool to convert the output values to the desired linear unit for the NEAR_DIST field.
Note: In this article, the NEAR_DIST field values are in meters and are divided by the approximate value of 1609 to convert the values to miles. Use the appropriate formula to convert the values to a different linear unit in the Calculate Field tool.
The image below shows the NEAR_DIST field values displayed in miles and within the search radius of the Near tool in ArcGIS Pro.
Artikel-ID: 000027090
