BUG
When images or objects (such as JPEGs, BMP files, or Excel spreadsheets) are inserted in an ArcMap layout with a page size that is larger than the default printer's default page size, theyfail to draw or draw incorrectly when exported. Picture marker symbols, or areas with a picture fill, may also fail to render properly on export. Legend patches of web map service layers may become pixelated or fail to draw on export, as well.
Note: At ArcGIS version 9.2 and later, picture marker symbols that are converted to vector with the 'Vectorize layers with bitmap markers/fills' option may also fail to render properly outside of the default printer's default page size. Additionally, certain cartographic representations that draw as an inserted EMF can also be affected by this issue.
If the inserted object, image, or legend patch falls outside the default page size of the Windows default printer, Windows GDI drawing calls used by ArcMap may not properly draw the object or image on output.
It is highly recommended to use ArcGIS Pro for printing and exporting, especially when experiencing issues caused by the limitations of the ArcMap display engine. More specifically, ArcGIS Pro is not restricted by the graphical device interface (GDI) limitations that some users experience in ArcMap. For example, transparency is natively supported in ArcGIS Pro, preventing the rasterization of layers. Additionally, ArcGIS Pro supports transparency in layout elements.
Note: ArcGIS Pro does not support exporting Adobe Illustrator files; it is recommended to export using PDF or SVG instead.
Alternatively, on some printers, selecting 'Use Printer Paper Settings' in the Page and Print Setup dialog box alleviates the problem. See the link in the Related Information section for more information on how to use the Use Printer Paper Settings option.
Another option is to set the Windows default printer's default page size to a page size as large as or larger than the page layout that is being exported. For example, if the map document is a tabloid size (17 x 22), set the default printer's default page size to 17 x 22 or larger before opening ArcMap.
Artikel-ID: 000008590
