HOW TO
Verwenden von IF-Anweisungen im Werkzeug Feld berechnen in ArcGIS Pro
Last Published: July 5, 2024
Zusammenfassung
In ArcGIS Pro, the Calculate Field tool uses IF statements to calculate new values in the fields of an attribute table. This article highlights some common uses of IF statements using Python scripts in the Calculate Field tool in ArcGIS Pro.
Vorgehensweise
To access the Calculate Field tool, refer to ArcGIS Pro: Fundamentals of field calculations for more information.
Indentations are automatically inserted into the Code Block box when the script is written line by line.
Populate the field based on the value of another field
Use the IF statement to populate the field based on the value of another field. The following sample script populates a field with 'Y' or 'N' if the value in the X1 field is '1' or '0', respectively.
  1. In the Calculate Field geoprocessing pane, under Parameters, select a table for Input Table.
  2. Select a field for Field Name (Existing or New).
  3. Select Python 3 for Expression Type.
  4. In the Expression text box above the Code Block box, enter the following script:
reclass(!X1!)
The Calculate Filed Geoprocessing pane to set the Parameters
  1. In the Code Block box, enter the following script:
  • Sample script with the if...else statement.
def reclass(X1):
    if (X1 == 0):
        return "N"
    else:
        return "Y"
  • Sample script with the if...elif...else statement.
def reclass(X1):
    if (X1 == 0):
        return "N"
    elif (X1 == 1 or X1 == 2):
        return "Y"
    else
        return "Invalid"
The Code Blocks box with the valid script
Classify the field according to a range of values from another field
A field can be populated with different values according to a range of values from another field. The following script classifies the field according to the different ranges of values in the X1 field, with less than 101 classified as Class 1, and so forth.
reclass(!X1!)
def reclass(X1):
    if (X1 < 101):
        return 1
    elif (X1 > 100 and X1 < 201):
        return 2
    elif (X1 > 200 and X1 < 301):
        return 3
    elif (X1 > 300):
        return 4
Copy values from one field to another if the value contains a number
Use the .isdigit() function to copy values from one text data type field to another only if the value is a number, as shown in the example below.
myCalc(!PLACE!)
def myCalc(num):
    if (num.isdigit()):
        return num
    else:
        return " "
Copy values from one of two fields to another field
An IF statement can be used to copy the values from one of two fields that meets certain criteria. The following script copies a value from the X1 or X2 field to a new field based on the value in the X1 field.
def calc(X1, X2):
    if X1 == 0:
        return X1
    else:
        return X2
Change the value of the field if it meets the criteria of two fields
An IF statement can be used to change the value of one field that meets the condition of the two other fields. The following script changes the value in the ADDR:POSTC field to 'Closed' if there is a value of less than 10 in the X1 field and the value in the X2 field is 0. If it does not meet both conditions, the ADDR:POSTC value is changed to ‘open’.
def myCalc(X1,X2):
    if (X1<10)and(X2=='0'):
        return 'Closed'
    else:
        return 'open'
Artikel-ID: 000027512
Zugehörige Informationen
Zu Download-Optionen wechseln
