HOW TO
Beim Veröffentlichen eines Feature-Layers über ArcGIS Pro kann mithilfe von ArcPy eine Zeitzone festgelegt und die Sommerzeit angegeben werden, indem die Konfigurationseigenschaften für die Veröffentlichung geändert werden.
import arcpy import os import xml.dom.minidom as DOM import codecs import xml.etree.ElementTree as ET
def enable_extensions(sddraftPath, soe): doc = DOM.parse(sddraftPath) typeNames = doc.getElementsByTagName('TypeName') for typeName in typeNames: if typeName.firstChild.data == soe: extension = typeName.parentNode for extElement in extension.childNodes: if extElement.tagName == 'Enabled': extElement.firstChild.data = 'true' f = open(sddraftPath, 'w') doc.writexml(f) f.close()
def enable_configproperties(sddraftPath, soe, property_set): doc = DOM.parse(sddraftPath) typeNames = doc.getElementsByTagName('TypeName') for typeName in typeNames: if typeName.firstChild.data == soe: extension = typeName.parentNode # prp = extension.childNodes.getElementsByTagNameNS('PropertyArray') for extElement in extension.childNodes: if extElement.tagName == 'Definition': for definition in extElement.childNodes: if definition.tagName == 'ConfigurationProperties': for config_prop in definition.childNodes: if config_prop.tagName == 'PropertyArray': for prop in property_set: prop_set = doc.createElement("PropertySetProperty") attr = doc.createAttribute("xsi:type") attr.value = "typens:PropertySetProperty" prop_set.setAttributeNode(attr) prop_key = doc.createElement("Key") txt = doc.createTextNode(prop["key"]) prop_key.appendChild(txt) prop_set.appendChild(prop_key) prop_value = doc.createElement("Value") attr = doc.createAttribute("xsi:type") attr.value = "xs:string" prop_value.setAttributeNode(attr) txt = doc.createTextNode(prop["value"]) prop_value.appendChild(txt) prop_set.appendChild(prop_value) config_prop.appendChild(prop_set) f = open(sddraftPath, 'w') doc.writexml(f) f.close()
Hinweis: Beim Herstellen einer Verbindung mit dem Portal über "arcpy.SignInToPortal()" kann möglicherweise ein Fehler auftreten. Weitere Informationen hierzu finden Sie unter Problem: Unable to log in to ArcGIS Online using ArcPy.
if __name__ == "__main__": arcpy.SignInToPortal("https://www.arcgis.com/", "username", "password") # aprx = arcpy.mp.ArcGISProject("CURRENT") aprx = arcpy.mp.ArcGISProject(r"aprx path") m = aprx.listMaps('<Map_Name>')[0] # if to share selected layers # layers = m.listLayers() # lyr = layers[0] name = "service name" in_server = "https://server.domain.com:6443/arcgis/" sddraft = m.getWebLayerSharingDraft('FEDERATED_SERVER', 'MAP_IMAGE', name) sddraft.federatedServerUrl = in_server sddraft.copyDataToServer = False sddraft.exportToSDDraft("location and name of sddraft") #The desired timezone can be in UTC or PDT property_set = [{ "key": "dateFieldsRespectsDayLightSavingTime", "value": "true" }, { "key": "dateFieldsTimezoneID", "value": "<desired_timezone>" }] # To set time zone on hosted feature service, soe = "FeatureServer" enable_configproperties(sddraftPath, soe="MapServer", property_set=property_set) # Enable extensions on the map server enable_extensions(sddraftPath, "FeatureServer") # enable_extensions(sddraftPath, "VersionManagementServer") # enable_extensions(sddraftPath, "LRServer") print("Start Staging") arcpy.StageService_server("location and name of sddraft", "location and name of sd") print("Start Uploadinb") arcpy.UploadServiceDefinition_server("location and name of sd", in_server) print("Finish publishing")
Artikel-ID: 000024162
