HOW TO
When querying, exploring, analyzing, or editing data, selecting features can be used to identify or work with a subset of features on the map. Selecting features to calculate statistics, view attributes, or edit the set of features that make up a map layer is done by applying a selection.
The instructions demonstrate how to use the ArcGIS Pro Select By Attributes geoprocessing tool to identify a specific range of attribute fields for further analysis. In this example, the LEVEL_NO field in the Schools_all feature class is used to identify the attribute fields within the range of 2 to 4.
to open the Select By Attribute geoprocessing tool.
Note: By default, the query builder is in Clause mode. Toggle the SQL optionto open it in SQL mode.
Where <field name> is greater than or equal to <field value> AND <field name> is less than or equal to <field value>
<field name> BETWEEN <field value> AND <field value>
Artikel-ID: 000027112
