HOW TO
An attribute table may contain multiple fields with null values and by default, these fields are populated with an empty space. In some cases, some tools or functions do not execute if the fields are not populated with characters (non-nullable fields).
The following are two possible methods to replace null values in an attribute table.
Replace all the null values in an attribute table using the ArcPy module
import arcpy
path = r'C:\Users\User\Test\Misc\Test.gdb\Feature_Name'
fieldObs = arcpy.ListFields(path) fieldNames = []
for field in fieldObs:
fieldNames.append(field.name)
del fieldObs
fieldCount = len(fieldNames)
with arcpy.da.UpdateCursor(path, fieldNames) as curU:
for row in curU:
rowU = row
for field in range(fieldCount):
if rowU[field] == None:
rowU[field] = "0"
curU.updateRow(rowU)
del curU
This is the full script used in this article.
import arcpy
path = r'C:\Users\User\Desktop\Misc\Piracy.gdb\Continents'
fieldNames = []
del fieldObs
for row in curU:
rowU = row
rowU[field] = "0"
del curU
Replace the null values in a single field using the Calculate Field function with the Python parser
There are two options to replace Null values in a single field. Use the conditional operator in the Python parser, or if 3D Analyst is licensed, use the Reclassify function.
Using the conditional operator:
0 if !Field_Name! is None else !Field_Name!
Using the Reclassify function:
, and select Function.Reclass(!Field!)
def Reclass(arg):
if arg is None:
return 0
return arg
button and click OK.Artikel-ID: 000023190
