HOW TO
Entfernen von Z-Werten oder M-Werten aus einem Feature-Layer in ArcGIS Pro
Last Published: September 26, 2024
Zusammenfassung
By default, it is not possible to edit a feature layer with z-values or m-values in ArcGIS Online or Portal for ArcGIS. In some cases, it is necessary to remove the z-values or m-values to fully visualize the feature layer in Map Viewer. In this article, the z-values and m-values of a feature layer named River are removed in ArcGIS Pro.
The z- or m-values is present in the feature layer from the Source tab of the layer properties.
Vorgehensweise
In ArcGIS Pro, remove the z-values and m-values of the feature class using the Feature Class To Feature Class tool.
  1. Open the ArcGIS Pro project.
  2. In the Geoprocessing pane, search for and click the Feature Class To Feature Class tool. Refer to ArcGIS Pro: Run a tool in the Geoprocessing pane for steps to do this.
In the Geoprocessing pane, select the first option which is the Feature Class To Feature Class (Conversion Tools).
  1. In the Feature Class To Feature Class pane, configure the Parameters tab as follows:
    1. Select the feature layer from the Input Features drop-down list.
    2. For Output Location, click Browse…. The Browse.... icon. to specify the location for the output feature class.
    3. Specify Output Name.
In the Feature Class To Feature Class pane, configure the parameters in the Parameters tab.
  1. Click the Environments tab, and disable the z-values and m-values.
    1. Expand the Z Values node, and in the Output has Z Values drop-down list, select Disabled. Refer to ArcGIS Pro: Output has Z Values (Environment setting) for more information.
In the Feature Class To Feature Class pane, configure the Z Values node in the Environments tab and select Disabled.
  1. Expand the M Values node, and in the Output has M Values drop-down list, select Disabled. Refer to ArcGIS Pro: Output has M Values (Environment setting) for more information.
In the Feature Class To Feature Class pane, configure the M Values node in the Environments tab and select Disabled.
  1. Click Run. The new feature class created is automatically added to the map.
The image below shows the z-values and m-values are removed from the feature layer in ArcGIS Pro.
The z- or m-values is not present in the feature layer from the Source tab of the layer properties.
Artikel-ID: 000026846
Zu Download-Optionen wechseln
