HOW TO
ArcGIS Server creates map and image service caches in the server cache directory in a default location when configuring the ArcGIS Server site. In some cases, the location of the cache directory can be changed, for example, when the cache directory is taking up space on the physical machine, and must be moved to another drive. This article highlights how to locate the cache directory of an ArcGIS Server service.
Note: The location of the cache directory is also indicated on the Site tab.
Artikel-ID: 000027895
