HOW TO
Exportieren einer Karte als interaktive PDF in ArcGIS Pro
Last Published: February 15, 2024
Zusammenfassung
In ArcGIS Pro, maps can be exported as an interactive PDF. An interactive PDF allows layer visibility toggling, distance measuring, and enables viewing of selected attributes of a feature on the fly. Interactive PDFs store all the map information in a single file, making it a useful medium for sharing content when a network connection is not available. This article describes the steps to export a map as an interactive PDF in ArcGIS Pro.
Vorgehensweise
  1. Open the ArcGIS Project.
  2. On the Share ribbon tab, click Export Map.
  3. In the Export Map pane, for File Type, select PDF from the drop-down menu.
The File Type is set to PDF
Under Compression, ensure the Output as image check box is unchecked.
  1. Under PDF Settings, check the Export georeference information check box.
  2. In the Layers and attributes drop-down menu, select PDF Layers and Feature Attributes.
  3. Click Export.
The PDF Settings option
  1. Open the exported PDF in Adobe Acrobat Reader DC.
  2. Click Model Tree: Work with 3D objects in the navigation pane and expand the map layers.
The feature layer’s attribute table can now be viewed and interacted with in the PDF viewer as shown in the image below.
The Model Tree: Work with 3D objects in the navigation pane of Adobe Acrobat Reader DC
Artikel-ID: 000027943
Zugehörige Informationen
Zu Download-Optionen wechseln
