HOW TO
In ArcGIS Pro kann einem Projekt ein Feature-Service aus ArcGIS Online oder Portal for ArcGIS hinzugefügt werden. In einigen Fällen ist es zum Optimieren der Performance erforderlich, einen Feature-Service in eine File-Geodatabase-Feature-Class zu exportieren. Weitere Informationen finden Sie unter ArcGIS Pro: File-Geodatabases.
In diesem Artikel wird der Workflow zum Exportieren eines Feature-Service in eine File-Geodatabase-Feature-Class in ArcGIS Pro beschrieben.
Note: To view the data source of the layer, double-click the layer in the Contents pane to open its Properties dialog box and click the Source tab. In this example, the USA_Parks layer is a feature service feature class.![]()
Note: • Export Features To use the Export Features tool to export the service layer, follow the steps below. 1. In the Contents pane, right-click the feature service, click Data, and click Export Features. 2. In the Export Features pane, For Input Features, select the feature service layer from the drop-down list. In this example, the Location feature service layer is used. 3. Click OK.• Feature Class To Geodatabase Use the Feature Class To Geodatabase tool to export one or more feature classes or feature layers to a file geodatabase feature class simultaneously. In comparison with the Export Features tool, when a project has few geodatabases, the output geodatabase to store the exported feature class can be specified when configuring the tool. To use the Feature Class To Geodatabase tool, follow the steps below. 1. In the Geoprocessing pane, search for and select Feature Class To Geodatabase (Conversion Tools). 2. For Input Features, select one or more feature layers from the drop-down list. In this example, the Location, USA_Parks, and Vendors feature layers are selected. 3. For Output Geodatabase, specify the geodatabase to store the exported feature class. 4. Click Run.
In diesem Beispiel wird der Feature-Service in eine File-Geodatabase-Feature-Class exportiert.
Artikel-ID: 000029963
