HOW TO
When viewing or after refreshing the ArcGIS Web AppBuilder app, the pop-up message, 'Click to restore the map extent and layers visibility where you left off' is displayed at the bottom-right corner by default. In some cases, it is best to disable the pop-up if it is not required.
This article provides steps to disable the App State pop-up in ArcGIS Web AppBuilder.
Note: When the ArcGIS Web AppBuilder app is created, the App state check box is turned on by default. Refer to ArcGIS Web AppBuilder: App state for more information.
, and click Edit Application.
The App State pop-up is not displayed when viewing or after refreshing the ArcGIS Web AppBuilder app.
Artikel-ID: 000023449
