HOW TO
Ermitteln der letzten Anmeldung im ArcGIS Enterprise-Portal und in ArcGIS Online mit ArcGIS API for Python
Last Published: September 12, 2023
Zusammenfassung
The last login dates are helpful in determining the list of active users in ArcGIS Enterprise portal and ArcGIS Online. Administrators have the required privileges to view audit logs and remove non-active users to free up licenses for new users. The last login dates can be determined using ArcGIS API for Python.
Ursache
Vorgehensweise
Complete the steps below to determine the last login date in ArcGIS Enterprise portal and ArcGIS Online using ArcGIS API for Python.
  1. Import the necessary module, including the time module.
import arcgis
import time
from arcgis.gis import GIS
    1. Make an administrator connection to ArcGIS Enterprise portal or ArcGIS Online.
    gis = GIS("https://domain.esri.com/portal", username="user1", password="pass1", verify_cert=False)
    print("connected")
    ArcGIS Online
    gis = GIS("https://arcgis.com", username="username", password="password")
    print("connected")
    1. Search for the list of users in ArcGIS Enterprise portal or ArcGIS Online. Set the maximum number of users if needed.
    a_users = gis.users.search(query='', max_users=200)
    a_users
    1. Loop through the list of available users, and print the login record for ArcGIS Enterprise portal or ArcGIS Online.
    for a_user in a_users:
        if a_user. lastLogin != -1:
            last_accessed = time.localtime(a_user. lastLogin/1000)
            print(str(a_user. fullName) + " was last active on: {}/{}/{}\n".format(last_accessed[0], last_accessed[1], last_accessed[2]))
        else:
          print(str(a_user. fullName) + " has never logged in.\n")
    The following shows the full script:
    import arcgis
    import time
    #For Portal for ArcGIS
    #For ArcGIS Online
    print("connected")
    a_users
        else:
    The image below shows the result of the above script.
    Result of the Python script.
    Artikel-ID: 000022604
    Zugehörige Informationen
    Zu Download-Optionen wechseln
