HOW TO
Geoprocessing tools add metadata about their execution in a geodatabase. The metadata includes the tool name, its location, and the parameters used when geoprocessing logging is enabled. Enterprise Geodatabases with large metadata stored can impact the performance. GIS administrators and managers sometimes need to delete the geoprocessing history from a feature class or workspace metadata.
The geodatabase workspace, together with some feature classes, may have quite a bit of geoprocessing history contained in the metadata. Thumbnails may also be a big contributor to the total metadata. This can also increase over time as analyses are done on datasets within the geodatabase.
The size of the metadata in bytes can be checked for the geodatabase workspace, and the top 20 feature classes in an SQL Server geodatabase, by running the following T-SQL statement. Remember to replace <Database Name>. This statement assumes the geodatabase repository is owned by the sde user, otherwise use 'dbo' in place of 'sde':
SELECT TOP 20 datalength(documentation) Length, Name FROM <Database Name>.sde.GDB_ITEMS ORDER BY Length DESC;
The geodatabase workspace together with some feature classes may have quite a bit of geoprocessing history contained in the metadata. (Thumbnails may also be a big contributor to the total metadata.). This can also increase over time as analysis are done on datasets within the geodatabase.
You can check the size of the metadata in bytes for the geodatabase workspace, and the top 20 feature classes in an SQL Server geodatabase, by running the following T-SQL statement. Remember to replace <Database Name>. This statement assumes the geodatabase repository is owned by the sde user, otherwise use “dbo” in place of “sde”.
Remove geoprocessing history from feature classes in ArcGIS Pro
The capabilities that were provided in ArcGIS Desktop via the XSLT stylesheets listed are now available in ArcGIS Pro from the Metadata deleteContent method.
The script automates the process of deleting the metadata for all feature classes in an enterprise geodatabase, including feature classes stored in a feature dataset. Run the included Python script after updating the variables.
import arcpy
import os
from arcpy import metadata as md
# Update the following variables before running the script.
myWorkspace = r"D:\Databases\geodata.sde"
db_type = "SQL" #Set this to either "SQL", "Oracle or Postgres" if your db has spatial views. If not you may set it to "".
def RemoveHistory(myWorkspace):
##Removes GP History for feature dataset stored feature classes, and feature classes in the File Geodatabase.
arcpy.env.workspace = myWorkspace
for fds in arcpy.ListDatasets('','feature') + ['']:
for fc in arcpy.ListFeatureClasses('','',fds):
data_path = os.path.join(myWorkspace, fds, fc)
if isNotSpatialView(myWorkspace, fc):
removeMetaData(data_path)
print("Removed the geoprocessing metadata from: {0}".format(fc))
removeMetaData(myWorkspace)
print("Removed the geoprocessing metadata from: {0}".format(myWorkspace))
def isNotSpatialView(myWorkspace, fc):
##Determines if the item is a spatial view and if so returns True to listFcsInGDB()
if db_type != "":
desc = arcpy.Describe(fc)
fcName = desc.name
#Connect to the GDB
egdb_conn = arcpy.ArcSDESQLExecute(myWorkspace)
#Execute SQL against the view table for the specified RDBMS
if db_type == "SQL":
db, schema, tableName = fcName.split(".")
sql = r"IF EXISTS(select * FROM sys.views where name = '{0}') SELECT 1 ELSE SELECT 0".format(tableName)
elif db_type == "Oracle":
sql = r"SELECT count(*) from dual where exists (select * from user_views where view_name = '{0}')".format(tableName)
elif db_type == "Postgres":
sql = r"SELECT count(*) from information_schema.views where table_schema NOT IN ('information_schema', 'pg_catalog') and table_name = '{0}'".format(tableName)
egdb_return = egdb_conn.execute(sql)
if egdb_return == 0:
return True
else:
return False
else:
return True
def removeMetaData(data_path):
# Get the metadata for the dataset
tgt_item_md = md.Metadata(data_path)
# Delete all geoprocessing history from the item's metadata
if not tgt_item_md.isReadOnly:
tgt_item_md.deleteContent('GPHISTORY')
tgt_item_md.deleteContent('THUMBNAIL')
tgt_item_md.save()
if __name__ == "__main__":
print("Done Done")
Artikel-ID: 000027149
