HOW TO
CAD data can be added to ArcGIS Pro as a feature layer. The resulting CAD feature dataset is a read-only feature layer when CAD data is added to a map. When a CAD feature dataset is added to a map, a group layer is created. In CAD software, CAD layers are used to organize data and control visibility as well as the default symbolic properties of entities in the drawing.
The instructions provided describe how to use the CAD To Geodatabase tool in ArcGIS Pro to convert CAD data to GIS data. In this example, the Bldg1_L1.dwg CAD data file is converted to GIS data in ArcGIS Pro.
Note: Refer to ArcGIS Pro: CAD To Geodatabase (Conversion) for further information on the parameters in the CAD To Geodatabase pane.
Artikel-ID: 000026432
