HOW TO
In ArcGIS Pro, the Convert Time Field tool converts time values of a string or numeric field to a date field. The tool can also be used to convert time values stored in string, numeric, or date fields into custom formats, such as days and months.
The instructions provided describe how to use the Convert Time Field tool in ArcGIS Pro to convert a text field to a date field in an attribute table. The DATE_V field in the Nbo_Hood_Clip attribute table shown in the image below is converted to a DATE field in this example.
Note: Refer to ArcGIS Pro: Convert Time Field (Data Management) for further information on the parameters in the Convert Time Field pane.
Artikel-ID: 000026575
