HOW TO
Konvertieren eines Raster-Datasets in eine XYZ-Tabelle mit ArcGIS Pro
Last Published: July 27, 2023
Zusammenfassung
Several software packages can import data from an XYZ format. This article provides instructions to convert a raster dataset into an XYZ table with ArcGIS Pro.
This process requires the Spatial Analyst license.
Vorgehensweise
  1. Open ArcGIS Pro and add the raster dataset.
  2. Find the Sample tool. Refer to ArcGIS Pro: Find a geoprocessing tool for more information.
  3. In the Geoprocessing pane, select the desired raster dataset for Input rasters.
  4. Select the raster dataset again in the Input location raster or point features field. Ensure Resampling technique is set to Nearest.
  5. Specify Output table.
Screenshot of the Sample geoprocessing pane with the values highlighted
  1. Click Run.
  2. Once the geoprocessing is complete, right-click the new table. Click Open.
  3. Export the table and save it with the .txt extension. Refer to ArcGIS Pro: Export tables for more information.
The output text file is in the OID, Z, X, Y format. The image below shows the output file.
Image of a sample output file
Artikel-ID: 000023278
Zu Download-Optionen wechseln
