HOW TO
When license files for Portal for ArcGIS in My Esri are corrupted, it is necessary to obtain new license files. Although it is possible to do this by editing the existing license files for Portal for ArcGIS versions 10.7 or higher without first cancelling the old license files, complications may happen when overwriting files. Cancelling the old license files ensures that the newly imported files are read correctly. This article describes the workflow to cancel license files for Portal for ArcGIS in My Esri.
Note: The following workflow requires specific My Esri privileges. If the options are not visible, request for the necessary permissions from the organization's My Esri administrator.
Artikel-ID: 000024859
