Zusammenfassung
                    In ArcGIS Pro, the Minimum Bounding Geometry tool creates a feature class with polygons that indicate a minimal bounding geometry enclosing each input feature or a combination of input features. For either display, first-approximation spatial query, or spatial indexing purposes, minimal bounding geometry is used to indicate the general position of a geographic feature or dataset.
The instructions provided describe how to calculate the small polygon dimensions within a larger polygon in ArcGIS Pro.
                        Vorgehensweise
                    - Calculate the width of the small polygons.
- Start ArcGIS Pro and open the project.
 - On the ArcGIS Pro ribbon, click Analysis > Tools to open the Geoprocessing pane.
- In the Geoprocessing tool search pane, search for Minimum Bounding Geometry in the search bar, and click Minimum Bounding Geometry (Data Management Tools).
Refer to ArcGIS Pro: Minimum Bounding Geometry (Data Management) for more information on the parameters in the Minimum Bounding Geometry tool.
- In the Minimum Bounding Geometry pane, configure the following parameters.
- For Input Features, select the small polygon layer.
 - For Output Feature Class, define the name of the new polygon layer. Wards_MinBoundGeo is used in this example.
 - For Geometry Type, select Rectangle by width.
 - Check the Add geometry characteristics as attributes to output checkbox.
- Click Run.
- Identify the small polygons that are located within the desired big polygon and assign attributes to them.
- In the Contents pane, right-click the newly created minimum bounding geometry layer and click Attribute Table.
- In the minimum bounding geometry layer attribute table, click Add to add a new field.
- Provide a name for the new field, and for Data Type, select Text. The field name, Main_MBG, is used in this example.
 - Close *Fields: <minimum bounding geometry layer name>, and click Yes to save the changes.
- On the ArcGIS Pro ribbon, click Map > Select and select the large polygon on the map.
- In the Selection group, click Select By Location.
Refer to ArcGIS Pro: Select Layer By Location (Data Management) for more information on the parameters in the Select By Location tool.
- In the Select By Location dialog box, configure the following parameters.
- For Input Features, select the newly created polygon layer.
 - For Relationship, select Within, or any other option based on the desired result.
 - For Selecting Features, select the large polygon. The Main polygon layer is used in this example.
 - For Selection type, select New selection.
- Click Apply. Click OK.
 - Open the Attribute Table of the minimum bounding geometry layer.
 - Click Show Selected Records and right-click the newly created field. Click Calculate Field.
- In the Calculate Field tool dialog box, enter the name of the large polygon layer with single quotes, and click OK. The Main_MBG field values change from <Null> to Main.
- Export the attribute table to a CSV file format.
- In the Attribute Table of the minimum bounding geometry layer, click the three-bar drop-down menu icon above the vertical scrollbar, and click Export.
- In the Export Table dialog box, define a name for the new attribute table with .csv affixed at the end for the Output Name parameter. Click OK.
Refer to ArcGIS Pro: Table To Table (Conversion) for more information on the parameters in the Export Table tool.
