HOW TO
In ArcGIS Dashboards, Arcade expressions can be used to customize how the data points render for the list, indicator, and table elements. Depending on how the element is configured, a data point can represent a feature or a summary statistic. A single data point represents a single feature when using features, and each data point represents the result of a statistic when it is used.
This article provides the steps to add digit grouping formatting for the numerical field values in ArcGIS Dashboards. In this example, the field values in the Chickens, Broilers - Inventory, Chickens, Roosters - Inventory, Chickens, Pullets, Replacement - Inventory, and Chickens, Layers - Inventory fields are referenced.
next to the element, and click Configure.
displayText : Text($datapoint[<variable>], '#,###'),
The image below shows the table element without the Arcade expression.
The image below shows the table element with the Arcade expression.
Artikel-ID: 000027394
