HOW TO
Hinzufügen eines Callouts zu einem ArcGIS Pro-Layout
Last Published: January 18, 2024
Zusammenfassung
In ArcGIS Pro, callout labels can be added to highlight and point to features in the map layout without obscuring map data or details. This article provides the workflow to add a callout to an ArcGIS Pro layout.
Vorgehensweise
  1. Open the project in ArcGIS Pro.
  2. Add a layout to the project. Refer to ArcGIS Pro: Add a layout to your project for instructions.
The Project pane with the Insert tab open on the ArcGIS Pro group ribbon.
  1. On the Insert tab, in the Graphic and Text group, click Straight text.
The Graphic and Text group on the Insert tab.
  1. Draw the text element in the layout and type a text.
Lock the layout elements that do not require editing in the Contents pane so they do not move.
  1. In the Contents pane, double-click the text element to open the Format Text pane.
  2. In the Format Text pane, configure the callout.
    1. Click Text Symbol, and on the General tab, expand Callout.
    2. Click the drop-down arrow and select one of the options from the drop-down menu. In this example, Balloon is selected.
The Format Text pane to configure the parameters in the  Balloon Callout option.
  1. Configure the callout parameters and click Apply.
The Apply button in the Format Text pane.
  1. In the Contents pane, right-click the text element and select Show/Hide Leader.
The Contents pane with the Show/Hide Leader option.
  1. Click and drag the green rectangle of the text element in the layout to adjust the callout leader.
The green rectangle of the callout leader.
The image below shows the callout label with a leader added to the layout.
The callout label with a leader on the map.
Artikel-ID: 000027477
Zugehörige Informationen
Zu Download-Optionen wechseln
