ERROR
Web-Layer überschreiben: Der ausgewählte Web-Layer weist keine gültige Serververbindung auf und kann nicht überschrieben werden
Fehlermeldung
When attempting to overwrite or add a web layer to a map in ArcGIS Pro with Portal for ArcGIS, the following error is returned:
Error:
Overwrite Web Layer
The selected web layer does not have a valid server connection and cannot be overwritten.
The error message: Overwrite Web Layer The selected web layer does not have a valid server connection and cannot be overwritten is returned when attempting to overwrite a web layer in ArcGIS Pro
Ursache
The ArcGIS Web Adaptor used to federate ArcGIS Server is configured with incorrect information. This happens when the original web adaptor is removed, and the new web adaptor does not use the correct server URL.
Lösung oder Problemumgehung
The following workaround stops services. Esri recommends carrying out the workflow below outside the local machine's usage hours. Consult the assistance and permission of a system administrator if necessary.
  1. Log in to the ArcGIS Server Administrator Directory with an administrator account. Navigate to the following path:
https://gisserver.domain.com:6443/arcgis/admin/security/config
  1. In the Portal properties text box, take note of the serverUrl.
  2. Log in to ArcGIS Portal Directory with an administrator account. The user's information page is displayed upon logging in.
  3. Scroll to the bottom and click Servers. Click the relevant Server ID, and compare the Server URL with the serverUrl in Step 2.
  4. If the server URL information is different, proceed to unregister the ArcGIS Server web adaptor. Refer to ArcGIS Enterprise: Unregister ArcGIS Web Adaptor for instructions.
  5. Install and configure the new Web Adaptor. Refer to ArcGIS Enterprise: Install ArcGIS Web Adaptor and ArcGIS Enterprise: Configure ArcGIS Web Adaptor with Portal for ArcGIS for more information.
  6. Navigate to ArcGIS Server Administrator Directory Home > security > config.
  7. At the bottom of the page, click Update.
  8. In the Portal properties textbox, edit serverUrl by inputting the correct server URL.
  9. Click Update.
Artikel-ID: 000025470
Zugehörige Informationen
Zu Download-Optionen wechseln
