ERROR
Fehler bei der Ausführung des Werkzeuges. Auftrags-ID von "PublishServiceDefinition": jXXXXXXXXXXXXXX : ERROR 001487: Fehler beim Aktualisieren des veröffentlichten Service
Last Published: January 27, 2024
Fehlermeldung
When attempting to publish a service referencing an enterprise database or geodatabase in ArcGIS Server 10.5.0, the following error is returned:
Error:
Error executing tool. PublishServiceDefinition Job ID: jXXXXXXXXXXXXXX : ERROR 001487: Failed to update the published service with the server-side data location. Please see the server's log for more details.
In certain cases, existing services that use these connections may work properly, and data stores may validate successfully.
Ursache
The 'dsconnections.lst' file is not present in the following directories:
C:\arcgisserver\config-store\data
C:\Program Files\ArcGIS\Server\DatabaseSupport
This file is not generated when the 'Validate All' command is run via ArcGIS Server Manager. This issue is caused by a defective patch, the 'ArcGIS Server Geoprocessing Service Startup Patch' for 10.5.0.
Lösung oder Problemumgehung
To circumvent the issue, follow the steps outlined below:
  1. Remove the previously installed Geoprocessing Service Startup patch.
  2. Download and install the updated patch: ArcGIS Server Geoprocessing Service Startup Patch.
  3. Log in to ArcGIS Server Manager. Navigate to Site > GIS Server > Data Stores. Click Validate All.
    Image of the ArcGIS Server Manager Data Stores page.
Artikel-ID: 000019106
Zugehörige Informationen
Zu Download-Optionen wechseln
